Question about lowering
Old Nov 24, 2003 | 04:09 PM
jayman117's Avatar
I have a stock '94 Z28. I want to lower it a little and I found the Eibach lowering springs online. Can I just buy the springs and leave everything else the way it is? meaning the stock shocks/struts etc. My car has 70,000k on it with the original suspension
Old Nov 24, 2003 | 04:14 PM
You should probably upgrade the shocks to match the springs - particularly in place of the loose 70K stockers. Since you have to completely disassemble the front "coil over" shocks (they are not really "struts") you have no reason not to change the shocks as well, other than the added cost.
Old Nov 24, 2003 | 04:18 PM
94formulabz's Avatar
Some other things to seriously consider are relocation brackets. Your control arms will not be at their designed angle once you lower the cars ride height and you may experience wheel hop and poor traction.
If your rear end being off center ~.5" will bother you then you will also need an adjustable PHR and possibly jounce bump spacers.
- brent
jayman117's Avatar
what is a good combination of shocks and springs at not to much of a cost? I'm just looking for a little bit of a drop and a little bit better handling, nothing to dramatic
Old Nov 24, 2003 | 04:29 PM
94B&RZ-28's Avatar
I'm running Bilstiens and the porkit. Since I'm still rebuilding my car, I couldn'y tell you how the ride feel is
Old Nov 24, 2003 | 04:39 PM
RamAir95TA's Avatar
I porkit last night...
Sorry...couldn't help myself.
Old Nov 25, 2003 | 12:36 AM
ZyberMunster's Avatar
I put in some SLP take-offs when I did the springs. Worked for me.
Laterzzz...
Old Nov 25, 2003 | 02:21 AM
johnny o's Avatar
You may also want to consider an adjustable torque are since lowering will change the pinon angles. I'd wait until after and see if you get more vibrations and if you do then you'd need one. Just a heads up on a possible expense.
Old Nov 25, 2003 | 04:14 AM
S.J.S.'s Avatar
I got the Pro-Kit with the stock springs. I've had them for about 50k now with no problems. But I do have wheel hop now that I never had. Getting Spohn LCAs and relocation brackets next week.
Old Nov 25, 2003 | 11:29 AM
BigJustinZ28's Avatar
I haver eibach lowering spring and kyb gas adjust shocks and my car wheelhops like a son of a bitch !!! Im probably gonna try lca relocators , hope that will help a little !!! Although I must say besides the wheelhop at the track it handles very well with this setup.
Old Nov 25, 2003 | 01:28 PM
Originally posted by S.J.S.
I got the Pro-Kit with the stock springs.....
How did you fit two sets of springs on the car?
Noenav
Mar 1, 2019 07:38 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Jan 31, 2015 07:29 PM
