PLEASE HELP 95 lt1 into 96 chassis
Old May 29, 2019 | 06:01 PM
Sidewyz28's Avatar
95 lt1 into 96 chassis?
I’m going to be picking up a 96 z28 6 speed & planning on swapping my 95 z28 6 speed motor/trans/pcm everything from the 95 into the other car...is this possible? Any help/input is appreciated!
Old May 29, 2019 | 09:07 PM
Re: PLEASE HELP 95 lt1 into 96 chassis
Main problem may be mismatches between the 95 engine harness and the 96 chassis harness, if you planned to use the 95 engine harness. Best to keep the 96 engine harness, and leave the connectors for things like the after-cat O2 sensors, crank position sensor, and EVAP purge vacuum switch unconnected, since those parts don’t exist on your 95 engine.
mrlewis
Aug 11, 2014 02:59 PM
summer nights
Sep 28, 2012 03:56 PM
fast-enough
Apr 9, 2010 05:09 PM
ssbowtie1
Dec 18, 2009 11:11 PM
theratdude64
Aug 25, 2009 11:16 PM
