motor
Old Sep 28, 2012 | 10:27 AM
summer nights's Avatar
motor
Need a motor for my 1995 z,have a chance to get a great deal on a 96 lt1 long block..my question is ,can i drop this in with out changing the wire harness or do i need a 96 harness..thanks for the help
Old Sep 28, 2012 | 11:40 AM
Re: motor
It will work without changing the harness. The 96 will have a crank sensor, but you can just ignore that (there won't be a plug on your 95 harness to go to it-not a problem). It will also have an EVAP vacuum switch on the RH side of the intake (if you are getting that part). You can ignore that, too and just use the EVAP plumbing from your 95. Use your 95 coil and ICM, too.
Old Sep 28, 2012 | 12:38 PM
Re: motor
thanks for the info.
Old Sep 28, 2012 | 03:56 PM
Re: motor
You also need to swap your 95 knock sensor into the 96 block. 96 knock sensor is not compatible with the 95 PCM.
alex5366
Mar 27, 2015 03:30 PM
transam_388
Mar 15, 2015 11:53 AM
NewsBot
Dec 28, 2014 06:20 PM
