pinging problem between 1k-2krpm under load
Old Aug 8, 2003 | 06:33 AM
  #16
superadobo808's Avatar
i guess ill take the car to a shop on monday, thank you for all your info predator. Could it be a fuel problem, running too lean? And if the car only make that sound and loses power in 3rd and 4th in between 1k and 2k rpm, will the shops computer be able to pick it up or will i have to drive with the computer? thanks.
Old Aug 8, 2003 | 06:36 AM
  #17
predator's Avatar
you will probably have to ride with them and point out the noise....when they put the comp on it ti will tell them if its running lean...i dont think so on the lean thing though........on that pingign does it sound like rattling does it stay in harmony with the crankshaft , camshaft remeber the cam turns 2 times slower than the crank so which is it in harmony with
Old Aug 8, 2003 | 06:42 AM
  #18
hey, yeah, it does sound somewhat like a rattle. um.........as far as what it is in harmony with, i dont know. i does go tick tick.... tick tick.....tick tick, has no power and then it goes away when i either go faster than 2k or down shifts.
Old Aug 8, 2003 | 06:44 AM
  #19
predator's Avatar
does it sound like valve ratle like bad gas or timing to far advanced..or like when a car diesels and you hear the valves ratling when shutting off but wnts to keep going
Old Aug 8, 2003 | 06:49 AM
  #20
honestly, im not sure, but it doesn't sound like deiseling. As far as gas goes, i have 92 chevron in right now, about 3/4 tanks full. Ive never touched the timing, would the timing change? Do our cars automaticly retard when pinging is there? Sorry about all the questions, but your really helping. thanks
Old Aug 8, 2003 | 06:55 AM
  #21
predator's Avatar
well we really cant screw with the timing it is done by the comp if the knock sensor is picking up knock it will retatrd timing and make you lose power .....have a diag. run on it and it will tell them if you are geting knock also it could be the opti going out dont take it that it is but quite possible like i said take it to a good shop probably GM and make sure they do a running diag on it and make the car do what you are saying....you will probably come out better than just putting parts on the car wasting you money
Old Aug 8, 2003 | 07:41 AM
  #22
MetallicTrans96's Avatar
I had the same problem as you did and cylinder #7 wasnt firing...because the plug wire had a gash in it and was grounding itself out.
edman
Mar 13, 2015 09:39 PM
Bignasty85
Mar 3, 2015 04:05 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Noenav
Dec 6, 2014 07:35 PM
GigaMp3z
Feb 20, 2003 02:57 PM
