picking up speed problem
Old Jan 26, 2009 | 10:37 PM
superstitz's Avatar
when i step on my gas my 94Z28 take a few moments to get up to speed. i was wonder if I should change out my (TPS) throttle postioning sensor. Or if anybody has any other things i should check!
Old Jan 26, 2009 | 10:42 PM
Have you ever had it scanned?
Could be as simple at a torn air inlet bellows between the MAF sensor and the throttle body. Does it seem to misfire before it responds to the throttle?
Old Jan 27, 2009 | 11:16 AM
superstitz's Avatar
Thanxs, I"ll try that, but I just replace the intake.
Old Jan 27, 2009 | 06:03 PM
Then perhaps the bottom edge of the bellows is folded under, and not fully on the throttle body.
Old Jan 28, 2009 | 09:46 PM
superstitz's Avatar
thanks tried that and everything was fine. would the air temp being loose be a problem
Old Jan 29, 2009 | 05:19 AM
It would be allowing air to bypass the MAF, so it might have a minor impact, but not likely enough to cause the engine to take a while to take "a few moments to get up to speed".
Old Jan 29, 2009 | 10:34 AM
trippin holyman's Avatar
you dont have a tps, our cars have a cable.
Old Jan 30, 2009 | 10:09 AM
Incorrect. Yes, we have a throttle cable.... and YES, we have a TPS The "TPS" is the throttle position sensor. It is on the passenger side of the throttle body. It is used by the PCM to determine throttle position, determine when to put the engine into power enrichment mode, when to respond to rapidly moving throttle, etc.
You appear to confusing the TPS with the throttle position actuator that is used in the cars with "drive by wire" throttle actuation.
You need to get under the hood more often.....
Courtesy of Shoebox:
DirtyDaveW
Dec 1, 2016 05:37 PM
Britbilly
Jan 7, 2015 08:49 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
siguy
Nov 27, 2014 10:07 AM
