People with LT4 Hot Cam
Old Apr 14, 2003 | 04:11 PM
  #46
Fast Caddie's Avatar
Originally posted by mebanditws6
Go with the hot cam kit as it already includes a new timing chain, lifters, and maybe something else (can't remember).
The kit has the cam, springs, shims, retainers, rockers, and locks. You have to buy the gaskets, timing chain, lifters, etc seperately. You really don't need new lifters unless you have a ton of miles on your ride.
Old Apr 14, 2003 | 04:57 PM
  #47
My94RedZ28A4's Avatar
Thumbs up
See sig for times...
Old Apr 14, 2003 | 06:51 PM
  #48
Dan Oldham's Avatar
BTW, what was done to your BC4 when it ran the 13.6@103? Also is yours an M6 or A4?
Jason
Just a Flowmaster muffler, Hyperjunk Power Programmer, airfoil, Moroso CAI, and a ton of luck. It's an A4 with 3.23s. My best EXACT time was 13.67 @ 102.7mph. I rounded off the mph high, and time low. I guess I would be running closer to a 13.7 but hey, I'm technically not lying. It did run a 13.6.
Old Apr 14, 2003 | 11:02 PM
  #49
Wild1's Avatar
Has anyone thought about the Crane Cam that is CARB legal? It puts out some good numbers... I believe the numbers were 218/218, 280/280, 116 LSA and .498 on 1.5 RRs.
Old Apr 15, 2003 | 02:43 PM
  #50
onebadponcho's Avatar
Again, there's a lot of good cams out there for the LT1. Man, I sure like mine . I can't wait to see what it will do at the track, but I can tell you, it goes like a cheetah on crack! Oh, did I mention how driveable it is? I get over 27mpg on the highway and that's with a stock tune. It chops pretty good at idle, and it pulls 15.5psi vacuum @ 800rpm; but bump the idle up to about 900 and tune it, the car would sound near stock.
Old Apr 16, 2003 | 04:59 PM
  #51
Wild1's Avatar
Congrats on the gas mileage. I'm running stock with about 15 city and 17 hwy. It's all part of the package, so yours must be dialed in good!
Old Apr 16, 2003 | 08:57 PM
  #52
Wild1, you must have an A4 w/3.23 gears. I had a '93 Formula with an A4/3.23 gears and it got 17mpg all the time no matter what. That's why I love my M6! My mileage and power will only get better after I get it tuned.
Old Apr 16, 2003 | 09:16 PM
  #53
Mir Hussain's Avatar
Who makes CAM like this 204/218 551/555 117.5
or Can I have Custom make this Cam ?
Cost Pro and Cons ?
Old Apr 16, 2003 | 09:20 PM
  #54
Dan Oldham's Avatar
Cost Pro and Cons ?
I don't believe that custom cams are that expensive to have made. I thought I remembered Crane making custom cams for people, and the price really wasn't too outrageous......maybe around $250-$300 range or something like that. You should call some reputable cam manufacturers like Crane, Lunati, Edelbrock, etc.
Old Apr 16, 2003 | 09:28 PM
  #55
O thanks DAN.......
I wonder how this CAM sound like........ any CAM doctor have inputs on this ?
Come LT1 Wizz
Give me a HINT
Old Apr 17, 2003 | 01:07 AM
  #56
Cost Pro and Cons ?
I'm shooting from the hip here, but those sound like the specs off the factory Corvette LS6 cam, which obviously won't fit an LT1. You could probably get someone to grind one like that for you, but I wouldn't know why you would want to; unless your running boost or N20.
Old Apr 17, 2003 | 08:29 PM
  #57
Wild1's Avatar
Onebadpancho, I've got 4.10s and an M6. I was getting knock retard which was killing my timing but that has been corrected. That will kill some mileage but you're system seems to be set up great!
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
