PCV Valve Elbow & Codes 0174/0171?
Old Oct 1, 2010 | 03:56 PM
BLBncsu's Avatar
Hello all. I've been constantly getting codes P0174/0171 for lean conditions in both banks.
Took a look around the car today and noticed that the 90 degree rubber elbow coming off the PCV valve is almost completely ripped in half and barely there. I will replace it but was wondering if this could be triggering those codes?
Also is there anyway to just order or find the rubber elbow without getting the entire tube/rubber assembly?
Thanks.
Old Oct 1, 2010 | 04:28 PM
Yes, the air bypasses the MAF sensor, the MAF sensor only reads a small part of the air, the PCM fuels the engine based on the low MAF readings, and its running lean. The PCM sees its running lean, based on the O2 sensors, and starts adding fuel using the long term fuel corrections. When it can't add enough fuel, it sets the "lean" codes.
Look at Shoebox's website for part #'s and sources:
http://shbox.com/1/4th_gen_tech1.html
http://shbox.com/1/pcv_pipe.jpg
HectorM52
Jul 30, 2017 11:46 AM
lt1matt
Mar 21, 2015 07:35 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
grgguy
17
Feb 23, 2015 07:57 PM
91Bird305
Aug 5, 2002 01:39 PM
