pcm help
Old Aug 17, 2004 | 04:18 AM
best96camaro's Avatar
pcm help
Hi .....
I pay program (lt1 edit 95/94) for my z28 manuel gear.
I want to know how can uesit to give my car max power.
These my car:
camaro 95 lt1 e /t56 t
The part:
1-knn ram air.
2-bbk throttle bodeies/58mm.
3-port and polish cylinder heads and intake manifolds.
4-manly valve intake 2.02 exhaust 1.60.
5-wisco 4.030 bore forged piston flat top cr10:8:1
6-comp cams hr cam int exh
valve lift 540 562
duration@0.50 242 248
lope separation 112.0
(wahts timing change)
7-comp cam rockers 1.52 ratio.
8-hooker long tube headers.(cancel rear o2 sensor).
9-msd 6al+coil+wirs 8.5.
10-lt4 knoc sensor.
11-march pulleys.
12-ring and pinion 3.73.
please help me
(i dont have dayno )
Thanks.
Old Aug 17, 2004 | 07:40 AM
Re: pcm help
You need to read and search the programming forum and the internet for info to learn about programming. There is an awful lot to know.
Old Aug 17, 2004 | 01:31 PM
bunker's Avatar
Re: pcm help
Hey your not Russian are you? If so, kak dela
Old Aug 17, 2004 | 03:53 PM
Re: pcm help
Sounds Klingon.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
