pcm help
pcm help
Hi .....
I pay program (lt1 edit 95/94) for my z28 manuel gear.
I want to know how can uesit to give my car max power.
These my car:
camaro 95 lt1 e /t56 t
The part:
1-knn ram air.
2-bbk throttle bodeies/58mm.
3-port and polish cylinder heads and intake manifolds.
4-manly valve intake 2.02 exhaust 1.60.
5-wisco 4.030 bore forged piston flat top cr10:8:1
6-comp cams hr cam int exh
valve lift 540 562
duration@0.50 242 248
lope separation 112.0
(wahts timing change)
7-comp cam rockers 1.52 ratio.
8-hooker long tube headers.(cancel rear o2 sensor).
9-msd 6al+coil+wirs 8.5.
10-lt4 knoc sensor.
11-march pulleys.
12-ring and pinion 3.73.
please help me
(i dont have dayno )
Thanks.
These my car:
The part:
1-knn ram air.
valve lift 540 562
10-lt4 knoc sensor.
11-march pulleys.
please help me
Thanks.
Nayr
Mar 3, 2023 08:34 PM
Sounds Klingon.
