Pcm?
Old Aug 30, 2004 | 06:43 AM
tv559's Avatar
Pcm?
How hard is it to change the pcm?
Thanks,
Old Aug 30, 2004 | 07:42 AM
30696bird's Avatar
Re: Pcm?
VERY EASY!!! Make sure it's 94-95 or 96-97 because they are differant,and if you have an auto use auto...................manual use manual. It's under your hood, passenger side, right in front of the windshield, it has 4 plugs going into it with LOTS of wires. Take - termanal off battery, there are two 10mm bolts holding it in place. Unscrew those bolts, unplug the 4 wire harnesses, take out of plastic sleeve, pop in the new one..........nothing to it. Hope that's what you meant and this helps.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
