droping motor got a ? about trans elec. conector
Old Aug 28, 2004 | 07:23 PM
93transam1234's Avatar
well i have all the wiring off except for the wire bundle that goes down the back of the intake area, i am guessing that is the on for the trans because i havnt unpluged that yet.
So i am having a problem undoing the wires from the lil plastic clips that hold them to the block
if someone could help please.
Old Aug 28, 2004 | 09:01 PM
dreamer1q's Avatar
Re: droping motor got a ? about trans elec. conector
I guess I dont quite understand the question. Are you trying to pull the motor out the top or out the bottom? What wires are you trying to remove, and from what.
Old Aug 28, 2004 | 09:39 PM
If you are dropping it out the bottom, I would imagine you are leaving the trans connected (no reason not to). No need to disconnect the harness from the trans if you are pulling the harness with the engine.
Old Aug 28, 2004 | 11:57 PM
i am droping it out the bottom, how can i keep the harness hooked up? do i have to pull all the wires out of the fire wall?
from what it looks like the wire harness that pluged into the trans will be pulled if i try to raise the frame off the motor, and i dont see how i could leave it all hocked up
FYI i am swapping out the motor
Old Aug 30, 2004 | 07:34 AM
Ttt
Old Aug 30, 2004 | 08:02 AM
dreamer1q's Avatar
You can either disconnect the wiring harness from the motor and trans or you can disconnect the wiring inside the car on the passenger side under the kick panel. This will allow the harness to come out with the engine and trans. I have done it both ways, neither is really better then the other.
Follow the KISS theory. Keep It Simple Stupid. Just think in general terms, the motor has to come out, so ANYTHING holding it in the car must be disconnected. It really is just common sense and time to do it right. Good luck
cmyname1
Feb 19, 2015 08:38 PM
alphaauto
Jan 22, 2015 08:02 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jan 5, 2015 07:14 PM
