Pacesetter LT's causing Wires to burn!??!?!?
Old Jan 6, 2006 | 09:00 AM
DontMixWithRice's Avatar
Anyone else have this problem?
How do you solve this other than the obvious?(taylor ovc's)
Old Jan 6, 2006 | 09:03 AM
2000GTP's Avatar
Re: Pacesetter LT's causing Wires to burn!??!?!?
With the stock wire routing, I had to use zip ties to secure the wires away from the headers in certain spots. I did this for a couple of weeks until my OTVC wires came in the mail.
Old Jan 6, 2006 | 10:08 AM
FryedClutch's Avatar
yeah i had some serious plug wire burning issues i went with the OTVC wires its the only way to go in my opinion
but ive heard of people tucking them up tight to the block with zip ties and stuff and it working so either way
Old Jan 6, 2006 | 10:09 AM
OBE1 95Z28's Avatar
Zip ties have been know to melt too so if you go that route, monitor them so your wires don't move later and burn.
Old Jan 6, 2006 | 02:22 PM
thehunter's Avatar
When I put headers on my old 94 Z I burnt a wire within a week. So I went the Taylor OVC route and never looked backed. In fact it changing was a lot easier afterwards.
Mike
Old Jan 6, 2006 | 02:27 PM
2000GTP's Avatar
The zip tie method, for me at least, was just a temporary fix. I'm not sure what the long term results would be like but like stated, its always a good idea to poke your head under the hood and check.
Old Jan 6, 2006 | 02:40 PM
Javier97Z28's Avatar
Moderator
Been running stock routing for over 3 years now with my Hooker LT's. Zip ties did the trick and have not "melted" off.
I've only burnt one wire in those 3 years.
Old Jan 6, 2006 | 05:42 PM
97WS6SCharged's Avatar
When I still used the opti, I wouldn't route the wires through the stock location. I ran mine behind the AC compressor and up from the bottom. No zip ties, no burnt wires.
drptop70ss
May 4, 2015 08:22 PM
eanhl2004
Apr 4, 2015 12:01 PM
WildRidez
Mar 27, 2015 08:22 AM
grabbem88
Mar 18, 2015 01:25 PM
