Questions about running a single plane intake with EFI
Old Jan 6, 2006 | 10:34 AM
aintno6's Avatar
Can you still run a single plane intake setup without using a aftermarket pcm?
I ask this becuse I figure that the throttle body would have some kind of a tps sensor on it, and they must all send the same basic signal? Correct me if I am wrong.
Also, what are the chances that it would still be able to clear a stock Firebird hood? I understand that there will need to be a fabricated induction system made.
Please leave your input.
Michael
Old Jan 6, 2006 | 11:29 AM
turbo_Z's Avatar
Re: Questions about running a single plane intake with EFI
I have never done this but I dont see why you couldnt unless Im overlooking something.
About the clearance issue... probably depends on the intake you want but Ive never seen a conversion that fits under the stock hood.
Old Jan 6, 2006 | 01:03 PM
imnotfast's Avatar
Hotrodhawk has one on her bird. He is on motown muscle and do not know if he goes on this board. sure he can give you more of an idea.
Old Jan 6, 2006 | 05:45 PM
97WS6SCharged's Avatar
You can run a single plane intake with the stock computer, you just might need to extend or cut a few wires to length. As far as fitting under a stock hood... possibly. Fitting under the cowl... probably not without getting out the sawzall. You should PM Bret if you're considering it, he has done quite a few conversions.
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
cmdeshon
Dec 27, 2014 10:06 AM
Queens94z28
Dec 20, 2014 09:11 PM
Elcojoe
Nov 17, 2014 10:27 PM
