P1351 Never went away and now P1371 as well
Old Feb 14, 2010 | 10:25 PM
Hood_Lum's Avatar
So today I finally got a chance to play with the Camaro again.
I took the white wire out completely and used a new wire.
Also used an extra external wire for the ground to make sure that was good.
Getting 14v from the pink wire when car is running.
I've been getting the dtc p1351 and still haven't figured out the problem.
This time instead of letting the car stall I kept giving it gas and another code came up. P1371, something about the low res signal from the opti.
The harness from the opti to the plug next to the oil filler neck is new. As well as the icm, coil, and Accel opti.
Old Feb 15, 2010 | 09:20 AM
Did the engine start? Loss of the low resolution pulse pattern from the Opti prevents the engine from starting. The low res signal comes from the optical sensor module in the Opti. The PCM did not find a low res pulse while it counted 720 high res pulses. The code could be "stored", if the engine actually started and ran, even poorly.
Clear the codes and see how fast P1371 comes back. If it comes back immediately, its a problem with the optical module, or the wiring, anywhere from the Opti to the PCM.
Old Mar 2, 2010 | 01:28 AM
Hood_Lum's Avatar
Solution (Partial): Figured out why my car was constantly stalling. Bad Accel opti out of the box. Thanks goes to summit for making the exchange for me 8 months later. Went with a GM performance opti and car runs great now. Kind of.
With the stock OBD2 pcm the SES light is constantly on. Still giving me
P1351- IC Circuit High Voltage.
With the pcmforless OBD1 pcm the car is running great. Every now and then the SES light will come on for a few seconds. Got a code 41 - IC circuit open.
I will try replacing the white wire with an external wire again and hopefully will have better results this time. I'll keep you guys posted.
fastcam91
May 7, 2010 05:22 AM
Mike96z
Aug 27, 2007 10:49 AM
JimboManJones
Mar 11, 2006 07:46 PM
TCamaroSS
Aug 3, 2004 04:16 PM
96Z28Guy
Oct 8, 2003 06:35 PM
