%#$*& CHECK ENGINE
Old Sep 22, 2003 | 03:51 PM
96Z28Guy's Avatar
Mother F%#$*& CHECK ENGINE
Well I went to auto zone today again so I could get the codes written down. Instead of it just throwing out 2 codes, it threw out 8!!!!!!!!
P101
P103
P0200
P0300
P0336
P0420
P1351
P1371
It doesnt run bad, everything seems fine Im so confused.
Can anyone help me out here?
Thanks,
-Ryan
Old Sep 22, 2003 | 04:00 PM
madwolf's Avatar
That's a bit too many codes to show up at one time. Although there's certainly a possibility that they are real, it could also be a bad ground, or low system voltage or maybe a bad PCM.
Clean the ground near the PCM and then pull the PCM fuse for a minute or two and see if they go away.
Old Sep 22, 2003 | 11:51 PM
DSIM's Avatar
P101-Mass or Volume Air Flow Circuit Range/Performance Problem
P0103 -Mass or Volume Air Flow Circuit High Input
P0200- Injector Circuit Malfunction
P0300 -Random/Multiple Cylinder Misfire Detected
P0336 -Crankshaft Position Sensor A Circuit Range/Performance
P0420 -Catalyst System Efficiency Below Threshold (Bank 1)
P1351 -IC Circuit High Voltage
P1371 -DI Low Resolution Circuit
Hope this helps...
Old Sep 23, 2003 | 07:47 AM
If the genuises at AZ did not tell you if they were active or history codes, you could be chasing your tail. If they did not clear the codes, do so and then have it scanned again if the SES comes on.
Old Sep 23, 2003 | 11:11 AM
ttopz28's Avatar
What does this code typically mean?
I think my fuel-pump is going out, so would this in anyway confirm this?
Old Sep 23, 2003 | 11:21 AM
No. It means the after-cat O2 sensor is not seeing a reduction of oxygen that it would expect to see on the outlet of a healthy catalytic convertor. Either the cat is dieing, or the sensor is messed up.
Old Oct 8, 2003 | 06:35 PM
ttopz28's Avatar
Is there any way to test either of these (without paying someone else of course). Also, does anyone know what a new Cat. Converter or O2 sensor would run me?
David Dorris
Jan 17, 2015 08:10 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
