P1351
Old Aug 16, 2005 | 08:14 PM
simple's Avatar
P1351
DTC, ignition related, where too start looking?
Old Aug 16, 2005 | 08:52 PM
CamaroSS30thAnn's Avatar
Re: P1351
P1351 Ignition Coil Control Circuit High Voltage (GM)
not sure what that means but it seems to have somthing to do with ur coil
Old Aug 16, 2005 | 10:32 PM
Re: P1351
Check the wiring to the ICM or maybe the ICM is going bad.
Old Aug 18, 2005 | 06:32 PM
simple's Avatar
Re: P1351
any possibility that this code could be from a rich condition?
because i also thru 3 O2 codes as well p0153, p0154, p0155 (but the O2's are getting deleted with tuning next week so i'm not worried about dealing with them)
Old Aug 18, 2005 | 11:02 PM
Re: P1351
Not sure how a rich condition could cause an electrical fault to the ICM.
Old Aug 19, 2005 | 08:32 AM
Re: P1351
All three of the O2 codes are for B2S1.... slow response, no activity, and heater circuit. Has nothing to do with "a rich condition". That's a faulty sensor or a wiring problem.... not sure how they're "getting deleted with a tune"???
P1351 sets when the PCM detects an open IC control circuit. You have a problem on that circuit somewhere between the PCM and the ICM.
Old Aug 19, 2005 | 06:48 PM
simple's Avatar
Re: P1351
well, i changed injectors from 30's too 36's and didnt run the car for a while because the pcm hasnt been adjusted for the larger injectors yet (but i needed a vehicle one day and then the codes came on shortly after)
anyway, these codes popped up only after i changed out the injectors
i was wondering since the car was running rich before and now the larger injectors are in there possibly making it run using even more fuel then needed
i was wondering about the misfire code being from a rich condition from the injectors at the spark plugs. guess not
the O2's will not be in use anymore after wed. nor will the maf or KS, according too my tuner, with this being more of a track car (more so then street anyway) he prefers too tune without them in use. he knows more on that subject then i do as far as "deleting" and tuning with out them.
what is an IC control circuit? could you elaborate a little more for me?
Old Aug 20, 2005 | 12:44 PM
Re: P1351
ICM = Ignition Control Module. That's where the signal from the PCM goes, that tells the coil its time to fire.
http://shbox.com/1/coil_loc.jpg
Again, a rich condition would set P0172 or P0175 or both.
If you're [pouring 20% extra fuel into the engine, in addition to running the risk of washing down the cylinder walls, thinning out the oil and doing some serious damage, maybe you've coated the sensors so bad they don't work any more.
Old Aug 21, 2005 | 10:24 PM
simple's Avatar
Re: P1351
ok, i thought the IC circuit was something different
could this code be an intermittent thing? or from loose connections or the like?
and i think all the O2 codes are from the car running rich (i wont be driving it anymore until we get the fueling issue taken care of)
Old Aug 21, 2005 | 10:33 PM
Re: P1351
If you're still convinced the O2 sensor codes are from a rich condition, why did you ask in the first place? Apparently you don't believe what I'm telling you, so I'll back off.
Old Aug 21, 2005 | 11:06 PM
simple's Avatar
Re: P1351
so, in essence it would be from a rich condition if i'm thinning out the oil and its being burned thru the exhaust coating the O2's and causing them not too work.......does that sound really far fetched?
maybe its running rich but not running rich enuf too throw the codes you mentioned but still causing the above mentioned? could be from bad ring sealing?
if that isnt a possibility, what could be coating the sensors so bad that they arent working zanymore since they were before the injector swap?
isnt a by product of rich fueling, "black soot"...is it not possible that that "black soot" could have coated the O2's enuf too the point of death?
i'm just trying too ask questions that relate too the last thing i had done too the car after i last drove it that could possibly in one way or another cause or be a cause too the O2 problem!
no need to back off
lymlyt96
Aug 3, 2011 02:49 PM
firebird_7678
Apr 26, 2010 12:39 PM
Hood_Lum
Mar 2, 2010 01:28 AM
Mike96z
Aug 27, 2007 10:49 AM
