P0118 code..
Old Feb 17, 2008 | 08:22 PM
97_camz28's Avatar
P0118 code..
p0118 code just popped up the other day i know it means engine coolant temp sensor high input. i have done the 3 wire 1 sensor conversion about a year ago and havent had a problem with it until now. i replaced the sensor today and still didnt help. i pulled the wire loom apart and everything seemed fine. didnt know if the pigtail went bad if it would throw that code, the pigtail is a ac delco and is less than a year old but just seeing if anyone could help me diagnose what was wrong
Old Feb 18, 2008 | 11:58 AM
The code sets when the PCM sees more than 4.9V on the circuit. That would essentially represent an open circuit. You have to verify the continuity of the wiring from the PCM to the sensor.
Phillip May
Aug 29, 2013 08:41 PM
aknight_sa
Aug 10, 2012 03:37 PM
henryz28
Jul 9, 2011 11:15 PM
smithtim
V6 Tech
Dec 9, 2005 11:43 AM
Stephen 98z28
Feb 21, 2003 05:16 PM
