P0118
Old Jul 9, 2011 | 08:32 PM
henryz28's Avatar
P0118
My car is running rally rich and starts hard when it is hot, but starts easier when it is cold. I have already fouled a set of plugs in less than a couple hours of run time. Would a P0118 problem be causing my problem; that is the only code showing.
Old Jul 9, 2011 | 09:02 PM
Re: P0118
The coolant temp sensor is telling the PCM the engine is cold. There's a good chance the PCM is fueling the engine for cold start and cold operation, which is much richer than for hot operation. Fix it fast before the excessive fuel starts to wash the oil off the cylinder bores and you destroy the rings.
Old Jul 9, 2011 | 09:15 PM
henryz28's Avatar
Re: P0118
^ Thanks and yes I plan I fixing it asap; I don't want to hurt a motor that has less than 20mi on it. So is it the sensor in the water pump or head; I think it is the one in the water pump. It is amazing how a little problem with one sensor can screw up a motor; man is it ever running rich I guess it can dump a lot of fuel with the 30lb injectors it has.
Old Jul 9, 2011 | 11:15 PM
henryz28's Avatar
Re: P0118
Fixed it turned out to be a bad wire going to the sensor in the water pump. I soldered it back together and now it runs 10x better.
Phillip May
Aug 29, 2013 08:41 PM
aknight_sa
Aug 10, 2012 03:37 PM
97_camz28
Feb 18, 2008 11:58 AM
Stephen 98z28
Feb 21, 2003 05:16 PM
