Are these SA or NSA rockers?
Old Feb 18, 2008 | 01:03 AM
LSWHO's Avatar
Scorpion part #SCP1026??
Old Feb 18, 2008 | 05:39 AM
Guest47904's Avatar
Guest
Those are NSA and they are 1.7 : 1 and they use 7/16 studs.
Old Feb 18, 2008 | 11:32 AM
LSWHO's Avatar
I knew all that I just couldn't find a single place that said that they were self aligning or not.
Old Feb 18, 2008 | 11:39 AM
9formula4's Avatar
be careful though remember the valves are going to open further so you might want to make sure your not putting to much lift on it with the 1.7s, you dont want a valve kissing a piston top
Old Feb 18, 2008 | 11:41 AM
LSWHO's Avatar
What would the max lift be you think? I wasn't planning on doing a cam anytime soon. But if I did I'd probably do a BIG one. If need be by then I'll sell the 1.7s for 1.6s.
But what would the max lift be?
The set up I was planning:
10308-1 springs/ret/locks
14011051 gm guideplates
7608-16 pushrods
Maybe a GM 847 cam down the road or CC306
Old Feb 18, 2008 | 11:59 AM
9formula4's Avatar
if your on a stock cam then you should be fine but with the 306 or 847 I think you would run into problems. with the 847 your lift would be .611/.633 and the 306 would be .578/.612. You might want to check into it a little before going on just what I said. Im just forewarning you on the possibilities.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
