P0102 code
P0102 code
Hey Guys,
i have a 1997 TA with the LT1. Recently had the engine out so I thought to myself, I’ll mark and remove all the sensor connectors I’m not using. Needless to say now I’m throwing a P0102 code from the MAF. I have 5V at the yellow wire but nothing at the pink wire. What’s my next option? I tried tracing the wires back to where ever they connect too but looks like they run down towards to starter area.
Ive checked the #5 fuse beside the drivers door and the engine sensor fuse as well. Can I just hook up another 12v wire from the battery to it? Needless to say im getting frustrated with it!
Re: P0102 code
For some reason, the 1997 wiring harness seems to have a high failure rate for 12 volt power to the MAF sensor. The break occurs somewhere in the harness, after the splice that sends power to multiple devices. Worth trying to locate. But adding a new 12 volt wire is a common solution. You want ignition switched power, not unswitched direct from the battery. There is a spade lug (labeled “IGN”) in the fuse panel at the end of the dash that supplies switched accessory power and is protected by an adjacent fuse.
Do you have access to a factory service manual? If not, there’s a free download of the virtually identical 1996 manual here:
https://www.mediafire.com/?40mfgeoe4ctti
93transam1234
Apr 2, 2008 10:53 AM
notstock4long
Mar 11, 2004 01:53 AM
slverbullet
Feb 21, 2004 03:30 PM
