P/V clearance question
Old Jun 11, 2005 | 11:47 PM
SuperDavez28's Avatar
I'm about to put a cc305 w/1.6 rr 220/230 (.544/.544) and AFR 180cc heads with 2.02 1.60 valves on my stock pistoned lt1. Will the bigger valves cause clearance problems?
Old Jun 12, 2005 | 12:27 AM
1racerdude's Avatar
Re: P/V clearance question
The clearance need's to be checked with modeling clay. .080I/.100E min.(not hard just takes time) On a stock block the pistons are not in the block the same from one block to another.Is the .544 lift with 1.5 or 1.6 RR's?
Old Jun 12, 2005 | 12:29 AM
1.6
Old Jun 12, 2005 | 12:34 AM
1racerdude's Avatar
1.6
Dave,
I would check at least 1 cyl just for S&G and to be positive. The worst part is making your 2 lifters solids to check.
Old Jun 12, 2005 | 12:40 AM
I will be checking, guess I wont know for sure untill I do. But i'm not too worried I just wondered if these size valves generally have problems or not on the stock short block. I know the cam's not the biggest out there
Old Jun 12, 2005 | 12:44 AM
1racerdude's Avatar
2.00 I valves won't but am not sure of that extra .020.Never have run 2.020,it's either been 2.0 in a stock head or 2.080 or larger in converted heads.
Old Jun 12, 2005 | 08:22 PM
arnie's Avatar
:scratching head: A lousy .010" diff? You're just toying with him, right Larry?
Old Jun 12, 2005 | 08:30 PM
1racerdude's Avatar
NO
I don't know if his heads have differant valve spacing,don't know how far the piston is in the hole,and didn't want to lead somebody into something that will crash their motor.
It's not a big deal to check one cyl v bending and breaking stuff the first time you tach it out.
Rather safe than sorry....
Old Jun 16, 2005 | 12:31 AM
Is there any way I can get a definative anwser so I don't have to check the clearance. Anyone have these heads? afr p/n 908.
Old Jun 16, 2005 | 12:54 AM
SStrokerAce's Avatar
Dave, I am more than 100% certain that you will be fine with P to V on that setup fo shizzle.... I've seen crazier stuff clear with even bigger valves.
Bret
Old Jul 6, 2005 | 07:55 PM
Revis_Racing's Avatar
What about P/V clearance with stock heads with 2.02/1.60 valves?
Same cam.
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Jim S. '95 Z28
Jul 25, 2002 11:58 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
