P/V clearance question
I'm about to put a cc305 w/1.6 rr 220/230 (.544/.544) and AFR 180cc heads with 2.02 1.60 valves on my stock pistoned lt1. Will the bigger valves cause clearance problems?
Re: P/V clearance question
I will be checking, guess I wont know for sure untill I do. But i'm not too worried I just wondered if these size valves generally have problems or not on the stock short block. I know the cam's not the biggest out there
Originally Posted by 1racerdude
2.00 I valves won't but am not sure of that extra .020.
:scratching head: A lousy .010" diff? You're just toying with him, right Larry?
Originally Posted by arnie
:scratching head: A lousy .010" diff? You're just toying with him, right Larry?I don't know if his heads have differant valve spacing,don't know how far the piston is in the hole,and didn't want to lead somebody into something that will crash their motor.
It's not a big deal to check one cyl v bending and breaking stuff the first time you tach it out.
Rather safe than sorry....
GA93FORMULA
Jul 24, 2002 11:38 PM
