Overheating problem??
Old May 15, 2006 | 05:16 AM
rsjay's Avatar
I just installed my motor back in my 1994 Camaro LT1. I installed a LT4 hotcam kit. Motor runs great but the car appears to be overheating going up to 3/4 up the heat gauge. I tried getting the air out of the motor and seems to run fine for an hour or so then the gauge rises again. I installed a 160 degree thermostat. Any other suggestions what might be causing this? Should I just drain the coolant and start over again. Also I did have a leak in one of my hoses and fixed that problem so don't know if she got air from that or not.
Old May 15, 2006 | 06:05 AM
teke184's Avatar
Re: Overheating problem??
re-bleed it....it's most likely your problem
Old May 15, 2006 | 09:30 AM
OBE1 95Z28's Avatar
What ratio of coolant to water are you running?
Old May 15, 2006 | 09:46 AM
Did you get a 160deg t'stat specifically for the LT1?
Old May 15, 2006 | 03:31 PM
rsjay's Avatar
I got a 160 temp stat for a 94 LT1 camaro hypertech I believe. I can't say for sure what my ratio to coolant and water is because my buddy did that but I will find out. Should I remove the temp stat altogether and run the car at idling for 15 minutes to remove any air??
Old May 15, 2006 | 04:30 PM
cleangene's Avatar
if the fans are not set for a lower temp, it will never go down, or maybe a bypass switch to turn fans on.
Old May 15, 2006 | 05:36 PM
Follow the air bleed procedure on Shoebox's page to get the air out. You can't get the air out by opening up the system and removing the t'stat.
http://shbox.com/1/how_tos.html
Old May 15, 2006 | 07:20 PM
rsjay's Avatar
I have a slp fan switch installed and they are working. I just went out and opened my 2 bleeders and ran it for about 10 minutes. there appears to be some air coming out. The car was over half on the temp gauge just idling. How long do I keep these bleeders open and if there is air will it cause the car to run this hot?
Old May 17, 2006 | 06:20 PM
rsjay's Avatar
Ok. I got all the air out of the lines last night. Took if for only a 10 minute drive and they car appeared to be overheating again. I was just above the half way mark on the gauge. I ordered a new air deflector today from GM because I could not find the old one but will that make that much of a difference. I checked the lines when I returned and there appeared to be no air but just running hot. I have a new 160 hypertech stat installed. I guess I should remove this to make sure it is working properly? Any other suggestions on what may be happening here?
liamcg97
Nov 25, 2019 05:55 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
warmeck
Apr 16, 2015 05:50 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
