OTVC plug wires
Old Jun 15, 2005 | 09:35 AM
bigdog96Z's Avatar
OTVC plug wires
Who has used the Taylor OTVC wire set up and where did you route the wires after you cleared the headers and went over the valve covers? I haven't bought this kit yet but it looks like it will help eleviate the risk of burnt wires if I can figure out where to route the wires back to the opti. Any opinions or experience out there??
Old Jun 15, 2005 | 10:34 AM
INSTG8R's Avatar
Re: OTVC plug wires
I have this kit and am very happy with it. I burnt through quite a few wires before I changed to this setup. I also went with the side mount Taylor kit, which comes with brackets to run the wires along side the valve cover instead of over top of it. IMO it just looks better this way. As far as routing them, the driver side was easy, there is a good bit of room to just run them down to the opti. On the passenger side, I routed the wires behind the alternator and then down to the opti. There isn't a whole lot of room, but you just have to make sure they are tight and lay cleanly between the alternator and the valve cover. Again, when you run them down to the opti, make sure they are tight and are not going to interfere with the belt or anything else. I don't have any pics to post but if you do a search for OTVC kits you can probably find some people with pics of their setups. Good luck!
Brian
Old Jun 15, 2005 | 12:09 PM
TruDualed95Z's Avatar
Re: OTVC plug wires
Just a FYI, for the same price you can get a set of pre-cut OVC wires from elitesparkplugs.com and a set of Made For You wire looms from MFY. This way you wouldn't have to measure and cut the wires.
Old Jun 15, 2005 | 02:03 PM
luckyou03's Avatar
Re: OTVC plug wires
Here's mine:
Passenger side Pic 1
Passenger side Pic 2
Driver side Pic 3
I had to custom cut these and put the opti boot ends on.. which SUCKS!
Old Jun 16, 2005 | 05:21 PM
bigdog96Z's Avatar
Re: OTVC plug wires
Thanks a lot guys. Lucky that set up you have looks great. Just to be sure is that the top mount kit?
Old Jun 16, 2005 | 08:32 PM
ZMAN Z28's Avatar
Re: OTVC plug wires
I used to be a big fan of Taylor. I just made a set for OVTC wires 8mm from taylor, and they still had arcing problems at the spark plug ends. So I went with a set of elitesparkplug wires, and the quality of them are awesome. They are pretty much the same price, and I got the 1200 degree heat protection. I won't consider Taylor again till they make premade wires for OVTC.
ZMAN
Old Jun 16, 2005 | 09:28 PM
Re: OTVC plug wires
Yeah I just got mine in this past week with the 1200* heat protection on them and they're amazing! They look and feel more durable than anything I've dealt with as far as a plug wire goes.
Old Jun 16, 2005 | 11:50 PM
luckyou03's Avatar
Re: OTVC plug wires
ya, i like them. It is the top mounted kit.
Old Jun 17, 2005 | 11:49 AM
bigdog96Z's Avatar
Re: OTVC plug wires
Trudualed and Zman, do the 1200* wires from elite fit in the OVC 8mm looms? It looks like those might be better for the long term. I've also heard of guys having trouble with Taylor wires.
Thx
Old Jun 17, 2005 | 01:45 PM
ZMAN Z28's Avatar
Re: OTVC plug wires
bigdog96Z:
Yes they barely fit. It is a tight squeeze. It's not a perfect fit. But mine work with the 1200 degree heatprotection on ym elite wires.
Z
Old Jun 17, 2005 | 02:35 PM
bigdog96Z's Avatar
Re: OTVC plug wires
So if you had it to do over again would you buy the 10mm looms?
Sorry for the 20 questions, just want to do it right.
Old Jun 17, 2005 | 04:23 PM
ZMAN Z28's Avatar
Re: OTVC plug wires
nope. I might clearance mine someday, but I am happy with what I have.
Z
Old Jun 17, 2005 | 05:20 PM
fredmr39's Avatar
Re: OTVC plug wires
Mine is pretty identical to lucky's -- see cardomain page 3 in sig...
Old Jun 20, 2005 | 06:43 PM
blind527's Avatar
Re: OTVC plug wires
How good are the wires from elitesparkplugs.com with the heat shields? Would it be good if it's a little close to the header primaries? I never heard anyone burn any wires or boots etc. using OTVC wires. I'm just worried about the tight spaces.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
