Thinner headgaskets to bump CR
Old Jun 9, 2005 | 08:24 PM
BadBowS10's Avatar
Im building my LT1 for my truck with pistons that will give me apro. 10.28 to 1 CR. what thickness headgasket can i get to bump it up about .5 of a point to make it about 10.7 ? who mkaes them and where i can get them and such thats a lot
greg
Old Jun 9, 2005 | 08:28 PM
turbo_Z's Avatar
Re: Thinner headgaskets to bump CR
I believe on a stock LT1 if you change out the stock head gaskets with the gaskets GM put on the Impala LT1s then it would bump the CR from 10.5 to 11.0. Sounds like that should work out for you too but I hope somebody else varifies what I said...
Old Jun 9, 2005 | 08:47 PM
BadBowS10's Avatar
I called a parts house and they said the part number for the Impy SS and the fbody lt1 are the same for the headgaskets.
So no luck there. thanks though man
greg
Old Jun 9, 2005 | 09:03 PM
turbo_Z's Avatar
greg
Odd.. I know the impala gaskets are thinner but I just dont remember by how much exactly. A search in this area of the forum should give you a part number
Old Jun 9, 2005 | 09:06 PM
BadBowS10's Avatar
ok will do and thanks again
greg
Old Jun 9, 2005 | 09:31 PM
97WS6SCharged's Avatar
A half point of compression isn't going to make that big of a difference. If all else fails, have the heads milled a little bit.
Old Jun 9, 2005 | 09:38 PM
ulakovic22's Avatar
Impy head gaskets are 0.029 thick. I think the stock is like 0.049....I can't remember exactly.
Old Jun 9, 2005 | 10:01 PM
Jeff95TA's Avatar
I used Mr. Gasket (0.026").
Old Jun 9, 2005 | 10:03 PM
CANTONRACER's Avatar
I would change to a thinner head gasket before I were to mill some heads....quicker, cleaner.
But...nothing wrong with having them cleaned up a little and checking for flatness.
Old Jun 9, 2005 | 10:22 PM
BadBowS10's Avatar
i think im going to just go with the mr gaskett gasketts thanks guys
greg
Old Jun 19, 2005 | 04:27 PM
InsaneTA's Avatar
You are looking for the CAPRICE head gaskets, look for ones for a 95 with the 5.7 LT-1, don't get the baby (4.7) Caprice gaskets as they will be wrong. The Caprice uses Iron heads and the Impala SS uses aluminum from my understanding. The iron head head gaskets are the thin ones, look for ones that are pre-compressed if you are using them on aluminum heads. The thin Mr. gaskets are a good choice, just keep them in a cool place until you are ready to use them and peel the wrapper off carefully to keep from removing all the coating. Good luck, I'm doing a blown head gasket repair now and I'm keeping the thick stock gaskets as my heads were shaved mucho.
Old Jun 19, 2005 | 06:04 PM
SStrokerAce's Avatar
Mr Gasket PN 5716 are .026"-.027" thick
The other is the Impala GM gasket PN 12553160 at .028"-.029"
You want the total gap or "quench" between the top of the Piston at TDC and the head deck to be .040" if you don't have the block decked (it being stock still) then the thinner the head gasket the better.
bret
Old Jun 19, 2005 | 09:12 PM
marshall93z's Avatar
Both use iron.
Old Jun 20, 2005 | 05:30 PM
arnie's Avatar
Engines are identical.
Old Jun 20, 2005 | 07:19 PM
simple's Avatar
when you get those Mr. G gaskets, stick them in the freezer for a little bit before opening them, they have a problem with sticking together and peeling some of the black laminate coating off, it should help with that some!
Jeff1904
Jun 5, 2016 05:00 PM
IndyZman
Oct 22, 2015 02:17 PM
blaze309
Sep 8, 2015 05:27 PM
dylan1303
May 22, 2015 12:24 PM
BLK1997Z28
May 2, 2015 01:26 PM
