View Poll Results: What will you get to replace your dead OPTISPARK?
GM OPTISPARK $235.00
39
29.55%
MSD OPTISPARK $500.00
39
29.55%
Dyanaspark OPTISPARK $600.00
5.30%
Delteq system $695.00
31
23.48%
LTCC system $700.00+
21
15.91%
Multiple Choice Poll. Voters: 132. You may not vote on this poll
OPTISPARK replacement...What will you get next time: Delteq, MSD, GM....
Old Jun 26, 2006 | 02:06 PM
  #16
marzen's Avatar
Re: OPTISPARK replacement...What will you get next time: Delteq, MSD, GM....
Mine might be done as well...
it's between the OE unit or the MSD unit, but the MSD unit is still too new to have any solid feedback about it...
Old Jun 26, 2006 | 02:20 PM
  #17
Honda Hunter's Avatar
Originally Posted by quickmedic1
I too have a Dynaspark and trust me...It will fail. Mine lasted about 2 yrs and is now showing the same signs as the original that I took out. I left messages for service at Dynaspark and as of yet no reply. I paid $600 for the Dynaspark and feel the MSD unit with a 1 year warranty is no bargain. I could have gotten 2 GM opti's for what I paid for the Dynaspark.
What was the reason your dynaspark failed? Did it shoot any codes? My showed opti high res code and when dynapark took it apart he said there was oil in it
Old Jun 26, 2006 | 03:50 PM
  #18
96badbird's Avatar
Originally Posted by wrd1972
Wouldnt the PCM dial out whatever you manually advanced. I have not heard anybody comment on the timing adjustment.
i dont know any of the detail's about the unit only what ive read. most of the websites that sell like thunderracing.com state that you can adjust +5/-5 degress manuely
it would be interesting to read a detailed article about it.
Old Jun 26, 2006 | 03:52 PM
  #19
Z28LT1_Just_Nasty's Avatar
I'm waiting to see how the MSD replacements go. I'm interested in the +5/-5 degree adjustments on them. Plus I already have their cap and rotor and it has done nothing but good for the car.
Old Jun 26, 2006 | 04:05 PM
  #20
Colin91Z's Avatar
Just out of curiosity, why is the new Accell opti not a poll choice?
I remember a thread not too long ago where a few members had used it with good results, so why leave it out of this comparison?
Old Jun 26, 2006 | 04:46 PM
  #21
Mike96z's Avatar
Could you tell me the exact bracket etc. you bought and part numbers and where you got it. I am interested in this so I can do the LS1 type setup like you did.
U paid $170 for the coils and brackets and $399 for the LTCC
Who makes this kit and you got any pics? Thanks
Mike96z@yahoo.com
Old Jun 26, 2006 | 04:52 PM
  #22
bgmz282's Avatar
i have a guy i know who put the MSD on his impala. It took a crap within 24 hours
Old Jun 26, 2006 | 04:57 PM
  #23
greenz2895's Avatar
i got the ltcc and i just got the msd coils and just got the brackets from sun spec billet factory.as soon as i get everything in ill send pics.
  #24
hammersz28's Avatar
Delteq!!!!!!!!!!!!
Old Jun 27, 2006 | 10:55 AM
  #25
quickmedic1's Avatar
I have not taken it apart yet. When I do I will open it up and see for myself. I still have not got any responce back from Dynaspark yet.
Old Jun 27, 2006 | 11:41 AM
  #26
TheBoerg's Avatar
Where is the best place to buy the GM replacement? ($235)
Old Jun 27, 2006 | 01:28 PM
  #27
wrd1972's Avatar
Jason Cromer: 877-726-8295
(or 850-243-8826 - direct parts dept ph # - not toll free)
Sam Taylor Buick/Cadillac, Ft. Walton Beach, FL
Old Jun 27, 2006 | 01:44 PM
  #28
I got a response from Dynaspark. Eric told me the rebuild fee is $30 + parts. For under $200 the unit can be rebuilt and has a 1 year warranty. That helps anyway. Turn around time is 1-2 days from receipt of the unit.
Old Jun 27, 2006 | 01:53 PM
  #29
The PCM wouldn't make any changes at all. It assumes the Opti optical sensor and the nose of the cam are correctly indexed. Hence, if you adjusted the MSD to offset the optical sensor from the standard indexing, the PCM would still be telling the plugs to fire at a particular advance before TDC, but would not realize that TDC had been moved, relative to the Opti optical sensor. There is no feedback to the PCM with regrad to actual ignition events.
I seriously doubt the +/-5deg adjustable timing was put there to allow amateurs to tweek the timing. I believe it makes sense if used to allow a camshaft to be installed advanced or retarded, without throwing the optical sensor off - something that prevents you from altering cam timing on the LT1, unless you are willing to go into the timing tables in the PCM and alter every entry by the amount (remebering the difference between camshaft and crankshaft degrees) you advanced or retarded the cam.
Old Jun 27, 2006 | 01:55 PM
  #30
That's what I was told as well. Mine should be here soon. Mine is going to cost 250 though. Cant beat having a 2year warranty on a opti.
