View Poll Results: What will you get to replace your dead OPTISPARK?
GM OPTISPARK $235.00
39
29.55%
MSD OPTISPARK $500.00
39
29.55%
Dyanaspark OPTISPARK $600.00
5.30%
Delteq system $695.00
31
23.48%
LTCC system $700.00+
21
15.91%
Multiple Choice Poll. Voters: 132. You may not vote on this poll
OPTISPARK replacement...What will you get next time: Delteq, MSD, GM....
Old Jun 26, 2006 | 08:59 AM
wrd1972's Avatar
I am interested in what you guys will get the next time your LT1 OPTISPARK kicks the bucket. It looks like I am going to need one sometime soon, I have the symptomatic 5500 RPM stumble.
I know this topic is on your mind if you have an LT1. I hope that this will turn into a very comprehensive one stop replacement OPTISPARK thread.
Please post your thoughts on your decision.
Old Jun 26, 2006 | 09:05 AM
james007moore's Avatar
Re: OPTISPARK replacement...What will you get next time: Delteq, MSD, GM....
I have a FAST system with the factory opti-spark, and i NEED to upgrade to something else.....I am wondering what my options are..Does the FAST system make changing over easier or harder ?? I know a few have do it, but to my understanding it has all been custom work.....anything available yet ?
Old Jun 26, 2006 | 09:15 AM
ulakovic22's Avatar
I would switch to a Delteq setup I think. Many people have had success with longevity by taking the high voltage out of the opti. I like the idea of splitting up the cylinders into 4 coils as well. The only thing I'm not sure about would be having to clutter up the engine bay even more with wires and coils and plug wires, etc.
Old Jun 26, 2006 | 09:49 AM
Daniel6718's Avatar
i pull my gm replacement ipti to 7000 daily..no problems...did have problems with oreilleys replacements...i used 8 of them b4 i went to gm and got one...fine now
Old Jun 26, 2006 | 10:13 AM
danhr's Avatar
If LTCC made a complete kit, like delteq does, I would have gone with it.
The msd opti is too new... problems could still arise in it.
I dont know much about the dynaspark one
GM opti... yeah ok.. i'll get right on that
Old Jun 26, 2006 | 10:21 AM
wrd1972's Avatar
I am still not convinced how the MSD can be so much better. yeah it has the billet housing, better bearing, rotor and cap. But the internal corrosion and ozone issues would still remain unless it is super sealed up plus the general operation is exactly the same.
If it is that damn great it should have a lifetime warranty since it cost more than 2X the GM opti.
Maybe I am off here, maybe it is da' bom.b
Old Jun 26, 2006 | 11:10 AM
Gripenfelter's Avatar
I went LTCC with LS2 coils but it didn't cost me anywhere near $700.
I paid $170 for the coils and brackets and $399 for the LTCC
Old Jun 26, 2006 | 11:16 AM
96badbird's Avatar
beside being a better built unit i know that it has an adjuster on it that allows you to change the timing +5/-5 i guess that could be worth the extra $$$
Old Jun 26, 2006 | 11:35 AM
wrd1972's Avatar
Wouldnt the PCM dial out whatever you manually advanced. I have not heard anybody comment on the timing adjustment.
Old Jun 26, 2006 | 11:38 AM
sbs's Avatar
sbs
Won't be a next time... have a Dynaspark.
If I was replacing the original today I'd probably go with the MSD.
If I had a 95+ car I'd just use the GM part.
Old Jun 26, 2006 | 12:35 PM
fastchevy's Avatar
LTCC all the way
Old Jun 26, 2006 | 12:39 PM
Ricardo's Avatar
I would go with a GM opti again. I would disassemble it and check it and put some loctite on the screws holding the rotor in place then bolt it on. I agree that the MSD has not been tested in real everyday use long enough.
RG
Old Jun 26, 2006 | 01:03 PM
Honda Hunter's Avatar
I agree with what the Danhr said. If LTCC had a complete kit I wouldve got it a long time ago. I went with the Dynaspark because it seemed to be the middle ground at the time, 1 step above a stock Opti and mabey 1 step behind a deltech or ltcc setup. The MSD hasnt been proven yet and I refuse to jump on the bandwagon and swear it's the next messaih when only time will tell. I had a problem with my Dynaspark but I bought it used a while ago so the problem couldve been from me or the other person. DS customer service is pretty good and the complete rebuild is affordable. Ill stick with it until otherwise.
Old Jun 26, 2006 | 01:18 PM
BLDun's Avatar
I did the LTCC and wouldn't change a thing except I plan to take the time to reroute the wires so make them less visible. But, like Gripenfelter I didn't pay near $700 for mine. Coils, brackets, etc. $550.
Old Jun 26, 2006 | 02:02 PM
quickmedic1's Avatar
I too have a Dynaspark and trust me...It will fail. Mine lasted about 2 yrs and is now showing the same signs as the original that I took out. I left messages for service at Dynaspark and as of yet no reply. I paid $600 for the Dynaspark and feel the MSD unit with a 1 year warranty is no bargain. I could have gotten 2 GM opti's for what I paid for the Dynaspark.
