Optical Disc rubbing sensor
Old Jan 14, 2010 | 10:31 PM
HerbzHancock427's Avatar
Ive been tryin to diagnose why my car randomly shuts off lately. The car will die and will usually not restart for an hour or two. I have replaced ICM, coil, plugs, wires, and the complete optispark. When the car wont start I am also not getting signal to the ICM, no movement on the tach, and no fuel smell. I did also get the code p1351 todayhowever i have checked all the wiring and it is good. Just a few minutes ago I removed the Opti, pulled off the cap and the metal plate under the rotor and reinstalled the rotor. When i spin the opti by hand i can hear the disc barely rubbing the sensor once per revolution. Did I find my problem or not?
PS it is an autozone opti and cap/rotor
Old Jan 14, 2010 | 10:45 PM
RamAir95TA's Avatar
Not many people have luck with Autozone units. You might want to try a GM opti.
Old Jan 14, 2010 | 10:49 PM
yea im starting to feel the same way but does this sound like what could be causing the no start/dying? How centered in the sensor does the disc usually sit? I have a pic of the disc ill put up in a min
Old Jan 14, 2010 | 10:58 PM
I dont think that ring is supposed to be there.
http://c4.ac-images.myspacecdn.com/i...5fd36b78cf.jpg
Old Jan 15, 2010 | 07:04 AM
There should be no contact. The reman optis are a crapshoot.
Old Jan 15, 2010 | 07:31 PM
marshall93z's Avatar
No fuel smell?!
Old Jan 15, 2010 | 07:48 PM
wrd1972's Avatar
Every Opti I touch first comes apart to make sure the optical wheel does not rub the sensor. If it does, it will damage the sensor. This usually happens cause the pulse wheel is warped. Take that crap back and get another one.
If the problem remains, get a GM opti.
Old Jan 16, 2010 | 12:22 PM
Yep no fuel smell
Old Jan 16, 2010 | 12:47 PM
nielsencc86's Avatar
I would go with an msd opti. I had issues with my original and used the msd. 10k later and a leaky water pump and it still goes strong.
Old Jan 16, 2010 | 08:18 PM
Thats what im thinkin. I just finished puttin the new opti in and it runs like butthole
Old Jan 16, 2010 | 09:23 PM
Do a "Search" and read the feedback on the MSD Opti, before you jump to the conclusion that it is the greatest thing since the flush toilet......
Old Jan 16, 2010 | 09:27 PM
teamstream's Avatar
anyone had any issues with the summit brand opti's? i just bought one from them and he said its actually a GM Performance brand they say. I gave 250 for it.
Old Jan 17, 2010 | 03:11 PM
Dave1980's Avatar
It seems the best thing to do is get one that is closest to factory. Make sure sensor wheel is free and no contact, and locktight screws if no locktight has been applied (next to rotor). Most of the the aftermarket seems to use a lesser quality sensor.
Victor Lamb
Aug 26, 2017 02:52 PM
Lt1son
May 27, 2015 10:35 AM
May 1, 2015 01:14 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
ModdedNerd
Dec 25, 2014 05:51 PM
