opti-spark HELP
Old Apr 19, 2004 | 11:51 PM
Dizzy1's Avatar
opti-spark HELP
ok heres the deal first the ECM went bad after replacing with a new one then module went also now codes says the opti-spark is bad any one else had this problem ??
Also if you let it sit over nite next morning if will fire up and run about 1 min. tops then shut down and wont start till next morning for another 1 min. then shut down again.
Old Apr 20, 2004 | 06:04 AM
Generation specific engine tech questions should be posted on the engine specific forums.... in this case, "LT1 Tech". Moving it there.
To have a better chance at a meaningful answer, you might want to include basic info like the year of your car, clarify which "module" you replaced and the specific codes you are getting to indicate a problem with the distributor. If you clear the codes, do they return in the 1 minute operating window the next day?
Old Apr 24, 2004 | 09:36 PM
JP2005's Avatar
people please help me... i need ideas
please please please help and thanks
jp
Old Apr 24, 2004 | 11:14 PM
If you don't supply as much info as you can (like Injuneer was trying to tell you), no one is going to bother to try to "guess" your problem.
Formula Steve
Sep 19, 2023 08:31 AM
Canadian z28
May 19, 2004 06:36 AM
Dizzy1
Parts Wanted
May 1, 2004 06:07 PM
LS1-Maniac
Oct 16, 2003 04:33 AM
94DROPTOPZ28
Mar 1, 2003 02:44 AM
