Opti seal part number needed
Old Aug 18, 2004 | 12:28 PM
Chris 96 WS6's Avatar
Anybody have the GM part number for the optispark bearing seal that fits into the timing cover?
I have a pretty significant leak and it drips down onto the crank hub and gets slung all over the underside of the coil, water pump, etc. etc....quite nasty.
Old Aug 18, 2004 | 12:52 PM
sssalah's Avatar
Re: Opti seal part number needed
12552428 is for the opti drive shaft seal for vented opti cars.
Old Aug 18, 2004 | 12:54 PM
G-BODYT56's Avatar
Talking Re: Opti seal part number needed
You are in luck . You can buy that complete timing cover kit for $10.48 form Advance Auto Parts or any parts chain.
1995-97 LT-1 TIMING COVER SET- FEL-PRO P/N TCS-45956, which contains the Water Pump seal, Opti-Spark seal, Crankshaft seal, Waterpump gaskets, and Timing Cover gasket. HTH's .
They also sell the 1992-94 LT-1 TIMING COVER SET.
Old Aug 18, 2004 | 12:55 PM
LWillmann's Avatar
The part number is in my opti swap parts list post on the club site, Chris.
Old Aug 18, 2004 | 01:26 PM
Mtrhds94Z's Avatar
Check your water pump seal too, they aren't the greatest seal.. and if you have to change it get 2 they are tricky..
Old Aug 19, 2004 | 08:07 PM
Thanks guys!
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
CobraEatr
Jul 22, 2002 09:49 AM
