Intake Manifold Leak.
Old Aug 18, 2004 | 02:02 AM
Silvershark's Avatar
Ok, So I thought my intake manifold was leaking so I took it off, but when I looked on the back side for oil I wasnt able to find any excessive amounts on the back of the block. I noticed that there is oil driplets underneath the driver side of the car. I looked further and the only thing I could tell was that there was oil on the outside of my oil filter.
Any ideas where this leak may be coming from? I will be going ahead and pulling the motor here in a month or so to build a 383, however I am stumped as to where the oil leak is coming from.
P.S.
I also managed to round off my PCV valve bolts that go into the back of my intake. Luckily I have a powder coated one that I just purchased to go in, along with the delete EGR, PCV plates.
Old Aug 18, 2004 | 08:30 AM
Hyperspeed97z28's Avatar
Re: Intake Manifold Leak.
The oil pressure sending unit could be leaking ...
I believe its right above the oil filter ????
Old Aug 19, 2004 | 08:09 PM
Could you post a picture of the sending unit? I am unable to find it on my car. I found the oil pressure sensor right below the PVC valve.
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
