Opti seal part number needed
Anybody have the GM part number for the optispark bearing seal that fits into the timing cover?
I have a pretty significant leak and it drips down onto the crank hub and gets slung all over the underside of the coil, water pump, etc. etc....quite nasty.
You are in luck
. You can buy that complete timing cover kit for $10.48 form Advance Auto Parts or any parts chain.
1995-97 LT-1 TIMING COVER SET- FEL-PRO P/N TCS-45956, which contains the Water Pump seal, Opti-Spark seal, Crankshaft seal, Waterpump gaskets, and Timing Cover gasket. HTH's
They also sell the 1992-94 LT-1 TIMING COVER SET.
. You can buy that complete timing cover kit for $10.48 form Advance Auto Parts or any parts chain. 1995-97 LT-1 TIMING COVER SET- FEL-PRO P/N TCS-45956, which contains the Water Pump seal, Opti-Spark seal, Crankshaft seal, Waterpump gaskets, and Timing Cover gasket. HTH's
.They also sell the 1992-94 LT-1 TIMING COVER SET.
Re: Opti seal part number needed
CobraEatr
Jul 22, 2002 09:49 AM
