Opti removal
Old Aug 15, 2004 | 04:01 PM
  #16
FastZinTennessee's Avatar
Re: Opti removal
My front timing cover started leaking oil and took out my opti. There will be a little oil there, but there shouldn't be a lot.
Old Aug 15, 2004 | 08:05 PM
  #17
weinerschizel's Avatar
Question Re: Opti removal
Ok. Got it on. Works like a charm. Didn't seem to have the power cutting out or any missfires anymore. Unfortunately though it's not working right yet.
I scanned the computer and noticed a TON of knock when I went to WOT. I'm 99.9% sure the motor is good as I JUST built it. Of course the the opti is good. What could this be from?
Thanks!
Old Aug 15, 2004 | 11:31 PM
  #18
Re: Opti removal
First off, you do have an LT4 knock module, right? Also, how is the car tuned? You might just need to pull some timing out. A tank of bad gas could also cause this......
Old Aug 16, 2004 | 10:07 AM
  #19
Re: Opti removal
Thanks for the advice! I've got a stock Knock module. Never knocked w/ stock programming. Which I reverted to after having difficulties.
Gas kind of makes since. I know it's got bad gas in it. After holding my hand by the exhaust for about 5 seconds, it becomes saturated in condensation. Car only knocks when I hammer it. Is it possible I could just drive around in a sane manner untill the gas is gone?
Thanks for the help!
ad356
Apr 11, 2015 08:49 AM
Iamherefornow
Jan 26, 2015 04:57 PM
pologreen97z
Dec 2, 2014 10:42 AM
