opti spark
Old Aug 17, 2015 | 09:35 PM
War Engine's Avatar
opti spark
Installed opti spark shaft and misalined it can i correct it or do i need new parts
Old Aug 17, 2015 | 09:37 PM
War Engine's Avatar
Re: opti spark
Its a 94 lt1
Old Aug 17, 2015 | 10:02 PM
Re: opti spark
Just correct the alignment.
http://shbox.com/1/93-94_opti.jpg
Old Aug 18, 2015 | 06:34 AM
War Engine's Avatar
Re: opti spark
Thanks I'll try to.
Old Aug 19, 2015 | 03:09 PM
War Engine's Avatar
Re: opti spark
Took it back apart and very carefull rotated the shaft until it fell in without a bump from my hand started the car for a sec without the water pump this time it ran. Put front back on engine runs great thanks.
Old Aug 19, 2015 | 03:35 PM
truthmatters's Avatar
Re: opti spark
I did the same thing installed OPTI -SPARK .Car started without WPump on .Put it back together cranks won't start .No spark .PCM ok Cannot find anyone to help 1995 LT1 also no code show either . 3 weeks now no car ..
Old Aug 19, 2015 | 04:03 PM
Re: opti spark
How did you scan it for codes? The 16-pin ALDL connector with the OBD-1 PCM can cause problems scanning it.
Did you check the harness connector for the Opti, damaged pins, damaged insulation, etc?
Old Aug 19, 2015 | 04:29 PM
Re: opti spark
I used the actron 9185 brand new scanner with obd 1 adapt cable . Again the car started with Opti spark install
never unplugged the harness after it started
Old Aug 19, 2015 | 04:36 PM
Re: opti spark
Just thought there might have been a chance you bumped it reinstalling the water pump.
Did you check for spark at both the plugs, and at the coil wire?
Old Aug 19, 2015 | 04:46 PM
Re: opti spark
NO SPARK I had pcm check it good .Strange it started before I installed everything .
Old Aug 19, 2015 | 08:39 PM
Re: opti spark
But.... Did you check for spark at BOTH the plugs and the coil wire?
Old Aug 19, 2015 | 08:42 PM
Re: opti spark
Originally Posted by injuneer
but.... Did you check for spark at both the plugs and the coil wire?
yes both no spark i just order a icm and coil .really don't think
it them but next option is take opti-spark again and replace again .
Old Aug 19, 2015 | 08:52 PM
Re: opti spark
Faulty optical cam position sensor in the Opti would set codes DTC 16 and or DTC 36. 16 shuts down the fuel system and does not turn on the SES light.
If the rotor fell off (did you loc-tite the rotor screws?) you would have spark at the coil, but not at the plugs.
Old Aug 19, 2015 | 09:23 PM
Re: opti spark
faulty optical cam position sensor in the opti would set codes dtc 16 and or dtc 36. 16 shuts down the fuel system and does not turn on the ses light.
again not codes also no spark at all the opti-spark was new all assembled thanks for reply
Old Aug 19, 2015 | 09:42 PM
TGGodfrey's Avatar
Re: opti spark
Go through and re-check all your work. You bumped something or unplugged something during the water pump install.
