Opti choices
Old May 10, 2006 | 05:08 PM
steve40's Avatar
Opti choices
looking for opinions on opti's
i see 4 choices
1. stock
2. dynaspark
3. accell
4. msd
anyone running any of the last 3...what are you thoughts about the unit and how are they holding up.
thanks
Old May 10, 2006 | 05:11 PM
FuryZ28's Avatar
Re: Opti choices
5.) Delteq
6.) LTCC
Old May 10, 2006 | 06:46 PM
Dave89IROC's Avatar
Re: Opti choices
Originally Posted by SGFuryZ
5.) Delteq
6.) LTCC
still need a working opti, so.........
Old May 10, 2006 | 07:18 PM
FuryZ28's Avatar
Re: Opti choices
Yeah, but does he know whether it's the cap & rotor (most common opti failure) or the optical sensor? The Delteq system uses ONLY the optical sensor. The condition of the rest of the opti is irrelevant. If it's just the cap & rotor, then he could add a Delteq and PROBLEM SOLVED...
Old May 10, 2006 | 07:24 PM
steve40's Avatar
Re: Opti choices
either way i still need an opti, and was just looking for a opti without having to do a conversion at this time since i'm building a complete new motor...those are options that i can look at later...but thanks
Old May 10, 2006 | 07:28 PM
FuryZ28's Avatar
Re: Opti choices
I would think any of the aftermarket units would be just as good as the OE unit, maybe even a little better. Regardless, I'd suggest looking to adding a Delteq (or similar unit) in the future, because it did wonders for my engine. Revs & accelerates SMOOTH, and it wraps up the tach quicker than before...
Old May 10, 2006 | 10:13 PM
MikeTR's Avatar
Re: Opti choices
I just brought a reman one from AutoZone for like $150ish. Seems to work just fine, but I only have about 2,000 miles on it so far.
Mike
Old May 10, 2006 | 10:31 PM
KGRESOCK's Avatar
Re: Opti choices
Hey Steve got a ETA on your project?
Kevin
Old May 11, 2006 | 04:10 PM
steve40's Avatar
Re: Opti choices
i've known people to have problems with the autozone ones...i'd rather just go with a complete new unit.
kevin...soon i hope....everything is taking way too long right now...either way we got to hook up if you still got those intake gaskets
Old May 11, 2006 | 04:44 PM
BlueCamaroZ28's Avatar
Re: Opti choices
OEM Opti #1104032. Summit and Paceparts have it for $290
Aug 24, 2015 06:41 AM
POLOVETTE 94
Aug 21, 2015 07:11 PM
Boss002
Jul 24, 2015 10:47 AM
Jul 17, 2015 02:47 PM
asilomar244
Jul 12, 2015 05:53 AM
