Omg Worst Luck Ever!!! Holy Crap!!! Help!!!
Old Nov 28, 2003 | 01:29 AM
  #46
CoUnTryMuZiCZ28's Avatar
But I cant tell if thats it... how can I be sure????
Old Nov 28, 2003 | 10:15 AM
  #47
TTT!!!!!!!!!
Old Nov 29, 2003 | 01:10 AM
  #48
another TTT and another post..
Old Nov 29, 2003 | 01:54 AM
  #49
Juiced Impala SS's Avatar
Reading your posts, I also have to say the opti but I do have a question before replacing it. Your sig says you have an MSD coil but then you state you have the Accel 300+ ignition. The 300+ comes with their own coil.
If you have the MSD coil, DUMP THAT POS!!!! I've seen to many that have gone bad, including 2 of mine and a friends. Symptoms were similar to yours. If you have the Accel, bypass the box and then try another coil if that's not the case. I'd find another F-Body friend so you can swap out the coil with the ignition module. Eliminate as much as you can before throwing parts and money at it to fix it. That can get expensive really fast.
As far as the head gasket is concerned, take it to a radiator shop. They can test the cooling system to see if Hydrocarbons are present, i.e. blown head gasket.
Good Luck!
Old Nov 29, 2003 | 04:32 PM
  #50
slopokrodrigez's Avatar
If jerking things around causes a problem than maybe tapping on things with the back of a screw driver might show up some problems. A gradual climb to red line Vs jumping on it doesn't sound like Opti.
Is there any way to scan it while your driving to see what some of the sensors are doing. I use my Snap-on scanner while I'm driving to view somethings, it might help you.
magman
Apr 15, 2016 03:08 AM
Bxlt1
Sep 29, 2015 03:18 PM
colts0455
Sep 22, 2015 02:03 PM
jackpawt883
Sep 10, 2015 08:53 PM
