Oil Weights and Ratings
Old Jun 25, 2003 | 01:09 AM
bobbykokinos's Avatar
Does anyone know if there is a webpage that says what weight oil to use during certain seasons??
I think the recommended for F-Body's is 5w30, but I see alot of people running 10w40 and such..
Old Jun 25, 2003 | 01:56 AM
Fatdog's Avatar
Cool
There is one,just can't remember where it is.I run 10-30 here in calif.,but in the colder climates,alot of folks like the 5-30 for start ups.Also,when the manufacturers test these engines,they get better mileage with the 5-30 for smog stuff and better mileage.Mycar has 104,000 miles on it,and I can't take the risk of 5-30,especially the way I blast it all the time.(I think the high tollerences have gone out the window at this point.)My02
Old Jun 25, 2003 | 01:58 AM
Don't Look Back's Avatar
I use the 5w30 in the winter, but in the summer here in NJ, all I do is drive and sit in traffic, so I go 20w50. I know thats a lot, but my family is made up of car people, and its what they use in their high performance Chevy's...
Old Jun 25, 2003 | 02:00 AM
Gives the car some good oil pressure too, I wonder why.....
Old Jun 25, 2003 | 02:11 AM
lt1form's Avatar
I use mobil 1 , 15w50 year-round, offers great oil pressure and since it is synthetic it is great in the winter too, starts right up first crank even when really cold.
Old Jun 25, 2003 | 02:13 AM
I use maxlife 5w30 and just broke 90,000 miles today. Should I step it up to 10w40??
Old Jun 25, 2003 | 02:33 AM
Blue96z28's Avatar
i use castrol syn. blend 5w-30, just becuase i've been going by the books....but what should i use in the summer, im here in oklahoma and it can get pretty hot, should i bump up to 10w-30 in summer?
Old Jun 25, 2003 | 06:54 AM
rskrause's Avatar
Moderator
Re: Oil Weights and Ratings
If your car is stock the recommended 5w30 is the best choice unless you live in an extremem climate. Since you're in Indiana, the 5w30 though be fine.
I use 15W050 Mobil 1 for a number of reasons. My car is not run in the cold part of the year, it's always warmed up for 1-2 min until being placed under load, and it is setup with slighty loose clearances to take advantage of the cushioning effect of a thicker oil film when the nitrous hits. The better "shear" strength of the 15W-50 is an advantage here.
Rich Krause
Old Jun 25, 2003 | 06:56 AM
bruecksteve's Avatar
I've run 5w30 Mobil 1 in my car since I've owned it and it now has 149,000 miles. Doesn't burn a drop of oil. I've got no reason to change what works.
Old Jun 25, 2003 | 10:54 AM
hairbear21's Avatar
5W30 is fine in these cars, but you will need to pay attention to the temps that it is rated for. 5-30 maxes out at around 90*F, and from that point on, 10W30 is recommended. I used to run 5W30 and even 0W30 in my old Camaro and never had a single problem. If you have a decent amount of miles on your car, I would run 10W30 in the summer and 5W30 in the winter. the 10-30 will not harm anything, and oil pressure will be fine.
Old Jun 25, 2003 | 12:03 PM
Kreinmc's Avatar
I just recently switched over to 20w50 to get some extra oil pressure. My engine is old and i beat on it like crazy. Plus its going to be 110 in Az this week.
Old Jun 25, 2003 | 12:34 PM
SilvercamZ28's Avatar
I live in nice warm NC and run Royal Purple's Full Synthetic 5W-30 with no problems... If it ain't broke don't fix it!
Noct
May 26, 2016 10:26 AM
carguy0119
Apr 11, 2016 11:11 PM
cmsmith
Apr 11, 2015 09:37 PM
cmsmith
Apr 10, 2015 10:03 AM
F550maranello2
Apr 1, 2015 11:10 AM
