Which oil pump?
Old Jun 10, 2007 | 12:32 PM
2QUIK6's Avatar
Which oil pump?
I'm going to be pulling the pan again as part of a cam swap, and figured it was time to replace the oil pump as its got a 100k on it.
Don't want a hi-vol pump, so what is the recommended pump to get?
Just a stock OEM pump or os there another thats highly used?
And should I get the white spring with the stock OEM pump for higher pressure or should that only be used with a deep pan?
I'm keeping the stock pan.
Old Jun 10, 2007 | 02:50 PM
12SCNDZ's Avatar
Check out the Jegs brand stock volume pump. Don't buy a new GM pump! They're based off the Melling M55 casting that's known for breaking. Moroso (as well as MANY others) also use the Melling M55 casting.
Frank
Old Jun 10, 2007 | 08:14 PM
2QUIK6's Avatar
Frank
The only Jegs one I see is for SBC excluding LT1, LS1, etc. The only pump I find online is the Melling M155?
Old Jun 11, 2007 | 06:36 AM
12SCNDZ's Avatar
http://web.camaross.com/forums/showt...=jegs+oil+pump
I ordered the 23501
Frank
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
NEWBIE T/A
Jun 14, 2002 12:27 AM
