Which oil pump?
Which oil pump?
I'm going to be pulling the pan again as part of a cam swap, and figured it was time to replace the oil pump as its got a 100k on it.
Don't want a hi-vol pump, so what is the recommended pump to get?
Just a stock OEM pump or os there another thats highly used?
And should I get the white spring with the stock OEM pump for higher pressure or should that only be used with a deep pan?
I'm keeping the stock pan.
Check out the Jegs brand stock volume pump. Don't buy a new GM pump! They're based off the Melling M55 casting that's known for breaking. Moroso (as well as MANY others) also use the Melling M55 casting.
Frank
Frank
The only Jegs one I see is for SBC excluding LT1, LS1, etc. The only pump I find online is the Melling M155?
NEWBIE T/A
Jun 14, 2002 12:27 AM
