Oil PSI
Old Feb 12, 2007 | 01:35 PM
LT4hotcam's Avatar
Oil PSI
My oil psi is always between 40 and 80, i use 10w-30 regular oil, if i put 10w-30 synthetic or 5w-30 will it make my oil psi go down. The reason i was asking is because i read on another thread that the oil psi being that high most of the time could make my oil pump go out, or could the psi be that high because its brand new oil pump?
Thankx
Old Feb 12, 2007 | 02:18 PM
Chris 96 WS6's Avatar
I don't think it would affect it enough for you to notice.
Old Feb 12, 2007 | 04:58 PM
If its a stock pump, with the stock pressure relief spring, it shouldn't reach any higher than 60psi. The spring will open the port and dump the excess oil. Is it a stock volume and/or stock pressure pump? Have you verified the actual pressure with a mechanical gauge?
As long as the last number in the oil's viscosity rating is "30", its going to have basically the same viscosity at 200*F. Doesn't matter whether its 0W-30, 5W-30 or 10W-30. The "30" tells you how "thick" it is at 200*F. The "-W" number tells you how thick it is at 0*F.
KYWes
Aug 4, 2015 01:54 PM
Nickster 7
May 1, 2015 09:04 PM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
