Oil Pressure help...FAST!
Old Apr 21, 2004 | 07:35 PM
Bad64chevelle's Avatar
OK here goes again....just installed white faced gauges....but didnt <kit advertised > take needles off...the face went on fine...but my oil pressure gauge now doesnt work. I beat on the car pretty good today, and got scared when i kept on hearing a thump noise, and i have NO idea where my oil pressure is at cause the needle doesnt move....it sits at a certain level and doesnt move.. what do I do? all my other gauges work fine...but the oil pressure is giving me hell...can anyone help me? anything is worth a shot, i just need some ideas!!! thanks!
Old Apr 21, 2004 | 08:02 PM
Robs97Z28's Avatar
if you had no oil pressuse, you would have a ton of lifter noise. About min after that the engine would die. IMO, I think it is you new gauge face that isn't allowing the needle to move freely. I would check that first.
Old Apr 21, 2004 | 08:09 PM
I did that...i ripped everything back out, moved the face around and started the car, and still nothing...the needle isnt touching from what i could see, i will rip it all out again (PAIN IN MY ***) and see what to do...if its not touching, do you have any other ideas? Thanks!
Old Apr 21, 2004 | 09:04 PM
Robs97Z28's Avatar
if you haven't alredy put a manuel oil gauge on and see what it reads. You just might have a bad sending unit.
Old Apr 21, 2004 | 10:24 PM
OK how would i go about that? I have a manual gauge, where would I connect to though? Thanks!
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
