Another belt tensioner question?
Old Apr 21, 2004 | 08:44 AM
JeffsWorld's Avatar
Question Another belt tensioner question?
After my failed attempt at installing my new chrome alternator (now bookend) I need to get the belt back on. I have searched for alternator, belt, and tensioner and all refer to loosening or relieving the tension by turning the tensioner/bolt clockwise. By "releasing the tensioner" or turning it clockwise, does it physically loosen the tensioner bolt? or just act as a pivot point (fulcrum) to release the tension on the belt and make some slack in the belt? When releasing the tensioner bolt does the tensioner go/spring back into place? Does the tensioner then need to be re-tightened counterclockwise? Does it need to be re-aligned? Do I need to torque the tensioner bolt down again? If so, how difficult is it to realign the tensioner? Is there anyway to possible mis-align the tensioner? Thanks. -Jeff
Old Apr 21, 2004 | 08:57 AM
It's easy as pie. When you pull down on the bolt, you are not loosening it, you are working against the spring tension on the tensioner. You will see easily when you do it. (I think the bolt is reverse threaded)
After you release the tension, flip the belt off the crank pulley, then let the tension off the tensioner. It will flip up higher than before because the belt is not holding it down.
Like I said, you will see what is going on when you do it.
Old Apr 21, 2004 | 09:17 AM
JeffsWorld's Avatar
Thanks for the info! I am hoping to get things resolved tonite after work.
Old Apr 21, 2004 | 07:39 PM
hazard2k's Avatar
Just to save you a little aggravation.. the wrench size is 13mm
Old Apr 21, 2004 | 09:26 PM
b-stevens's Avatar
1/2" incase you have english tools
Old Apr 21, 2004 | 10:22 PM
If it's 13mm (and it is), that's what should be used.
Old Apr 21, 2004 | 10:35 PM
b-stevens's Avatar
I suppose I'll keep that in mind next time
grabbem88
Feb 23, 2015 09:41 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
Snoman73
Nov 17, 2014 07:22 PM
1LEThumper
Jul 14, 2003 12:45 PM
94_Z28_ragtop
Sep 12, 2002 12:09 PM
