oil pressure ???
Old Aug 10, 2012 | 04:35 PM
  #16
wheelliftnpony's Avatar
Depending on your mileage, its probably a good idea to just go ahead and replace that oil pump while its out
Posted from Camaroz28.com App for Android
Old Aug 10, 2012 | 04:36 PM
  #17
Camaro350z28's Avatar
Re: oil pressure ???
there seems to be a lot of people these days not listening to advice. weird. your pressure is fine. no wonder cars have dummy lights instead of gauges lol
Old Aug 10, 2012 | 11:48 PM
  #18
dzltek's Avatar
Originally Posted by parkers Z28
don't know why I said degrees ?? my truck at idle has 40psi and my explorer stays at halfway no mater what rpm so what i thought was a problem with my camaro is really a problem with
my every day driver the explorer the gauge stays at the halfway mark at any rpm so I'm assuming
that the oil sending unit is bad or is it the gauge ?????
don't be so sad about that rod bearing it just gives you a reason to make it faster !!!!
HAHA, the only reason I'm sad is the money I had saved was going to be spent on speed parts alone. Now its all goin on a rebuild and some bolt ons and a cam. I got a helluva deal on a cc306, but its gonna be too much so it'll sit on the shelf for a little while I guess. I may put it in and let it be a good sounding turd!!! Haha
Old Aug 11, 2012 | 06:37 AM
  #19
Not every engine oiling system is the same. Do you wonder why the LT1 V8 oil pressure gauge only goes to 80psi, while the same Camaro with a 3.8L V6 has a gauge that reads to 120psi? Different designs. The engineers that designed the engine designed the oil pressure and oiling system to provide the lubrication required by the various components of the engine.
Give it up.
Old Aug 11, 2012 | 01:17 PM
  #20
parkers Z28's Avatar
Don't know that much about the internal components of a engine and how they work just the basic
i was assuming that oil pressure was oil pressure based on my three car's with two of them having
the same gauge and the other one just having a. high and low thought it was a 80 psi gauge also
Old Aug 20, 2012 | 05:31 PM
  #21
Thanks for the help guys. ford said that they had to replace the oil sending unit the gauge is now
working like it should. got the stall converter in melting the back tires off. LMFAO !!!
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
