Oil Pressure
Old Aug 23, 2003 | 07:06 PM
akafred's Avatar
Oil Pressure
I run 15 w 50 mobil one in my stroker and if i brake hard my oil pressure dives what is my problem? is it my oil pan?
also i want to run a standard delco plug non plat in my 12.5:1 hotcam pumpgas motor what plug # should i use? i would prefer somthing mabey a bit colder for less detonation?
Old Aug 23, 2003 | 07:48 PM
jkbadz28's Avatar
I think a Autolite 104 would be a good choice for a spark plug.
JK
Old Aug 23, 2003 | 10:09 PM
What oil pump and pickup are you using? What oil pan? Did you make sure the pickup was the proper depth in the pan? Did you tack the pickup to the pump?
This probably should have just been put in LT1 Tech. Moving it there.
Old Aug 23, 2003 | 10:37 PM
akafred's Avatar
SORRY
Old Aug 23, 2003 | 10:43 PM
akafred's Avatar
I have a high pressure oil pump, std pick up, and stock pan. and yes it is welded, it is 3/8" higher than the bottom of the pan.
what plug should i use?
Old Aug 25, 2003 | 03:03 PM
akafred's Avatar
plugs
so no one knows what plug number would be stock non platinium plug?
Old Aug 25, 2003 | 03:30 PM
Hotwire's Avatar
plats are 41-906
non plat rapid fires are #14
you can go to wwwacdelco.com and find crosses for them.
good luck.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
