Oil Pressure
Oil Pressure
I run 15 w 50 mobil one in my stroker and if i brake hard my oil pressure dives what is my problem? is it my oil pan?
also i want to run a standard delco plug non plat in my 12.5:1 hotcam pumpgas motor what plug # should i use? i would prefer somthing mabey a bit colder for less detonation?
What oil pump and pickup are you using? What oil pan? Did you make sure the pickup was the proper depth in the pan? Did you tack the pickup to the pump?
This probably should have just been put in LT1 Tech. Moving it there.
what plug should i use?
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
