oil level sensor on new lt1 383
Old Apr 3, 2021 | 01:25 PM
cybern8's Avatar
i bought my 383 from an engine builder and it came with the oil pan oil level sensor fitting plugged with a brass fitting. i think i can unscrew it and put the original oil level sensor in, but am wondering if there is a reason not to use the sensor, mainly being if it won't go in because it is going to hit something in the oil pan. i am contacting the engine builder about it but haven't heard back yet, and am wondering if any of you have run into this.
Old Apr 3, 2021 | 10:31 PM
DrewHMS97SS's Avatar
Re: oil level sensor on new lt1 383
Clearance of something is the only thing I can think of. I removed mine because my pan had zero clearance on the oil level sensor to the header.
Legit 0.
Old Apr 3, 2021 | 10:36 PM
cybern8's Avatar
wow. no kidding. i don't have that problem, and am more wondering if there is something *inside* the pan that the probe/float will hit.
Old Apr 4, 2021 | 09:02 AM
The oil pump is really the only thing in the sump. If it screws in, and you don’t bottom out on the pump, you should be fine.
Old Apr 4, 2021 | 10:57 AM
From Shoebox:
http://shbox.com/1/oil_pump.jpg
The oil level sensor would be to the left of the pickup in this upside down picture.
Old Apr 7, 2021 | 03:26 PM
Chimera96's Avatar
OP
FWIW my 383, stock pan uses the stock oil level sensor and I also have the windage tray installed....hope you do to
Miamispd
Jul 21, 2004 04:26 PM
S.J.S.
Jun 24, 2004 02:56 PM
ONELOUDKAR
Apr 19, 2004 10:03 PM
meangreen95z28
Apr 26, 2003 01:26 AM
Dave 96TA
Apr 10, 2003 05:15 AM
