Oil Leak Found!
Old Jun 22, 2004 | 09:38 AM
ASIM's Avatar
Oil Leak Found!
Hey guys:
I've posted some questions recently about an oil leak I have had for a few weeks. Took it to Straight Line racing here in Toronto and turns out it is coming from the crank case seal.
I'm looking at about $230 to fix. Not bad I guess.
I hadn't had anyone mention that before so I'm assuming it is rare and thought I should post it to let you guys know another possible cause for these drips under that car.
Thanks,
Asim
Old Jun 22, 2004 | 11:24 AM
Yeah, must be rare. I don't know what a crank case seal is. They must mean something else that we all call something else.
Old Jun 22, 2004 | 03:02 PM
ASIM's Avatar
Where the crank comes out of the block. What the ballancer is attached to?
Not sure of there is a more common name.
Asim
Old Jun 22, 2004 | 05:03 PM
Ah, I see. The front crank shaft seal.
$230 seems high to fix that, even at Canadian rates. A $7 part and maybe 45 minutes work with the right tools.
Old Jun 22, 2004 | 05:11 PM
simple's Avatar
i'm sure theres a writeup somewhere for the DIY'ers too.... ?
Old Jun 22, 2004 | 05:19 PM
KillWhitey's Avatar
mine is leaking oil from the timing chain cover. is that fix just as cheap? seems like a hell of a job
Old Jun 22, 2004 | 05:24 PM
KillWhitey's Avatar
im leaking oil from my timing chain cover. is that just as cheap to have fixed as the crank shaft seal?
Magenta_Hearts
Mar 29, 2017 08:54 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
artic94
Jan 17, 2015 11:19 AM
96z
Sep 5, 2002 07:53 PM
Dr. Weir
Aug 2, 2002 02:36 AM
