oil cooler delete
Old May 7, 2009 | 06:27 PM
stephenpen's Avatar
oil cooler delete
I've been searching for detailed instructions on removing my oil cooler. I understand what to do with the coolant hoses but I'm not sure if I just remove the adaptor and bolt the filter on. Will the bolt be too long or do I have to get a new bolt that the filter bolts on.
Old May 7, 2009 | 06:33 PM
bw_hunter's Avatar
There is a different filter mount when you delete the cooler. It's held in place with two small bolts. You canfind them on Ebay for small change...
Old May 7, 2009 | 08:18 PM
The_Bishop's Avatar
What year is the car?
Old May 7, 2009 | 08:25 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
When I removed the cooler on my '94, I did not need to buy an oil filter adapter. My cooler was mounted to the oil filter adapter. I did have to replace a couple of studs, which are used to mount the adapter to the block when it's used in conjunction with the cooler, with bolts. I actually bought an oil filter adapter because I was told it was necessary, but it wasn't. Perhaps on later models it's different. I believe the cooler design changed beginning in '95.
Old May 7, 2009 | 09:14 PM
stephenpen's Avatar
Its a 1995 M6 with a little oil leak. I just put a 383 in and think I'm leaking oil from where the oil cooler mounts. It sounded easy enough to remove so I want to start with the easy possibilities first. If its not this its the pan gasket or rear main.
Old May 8, 2009 | 12:35 AM
madhatter's Avatar
It is an o-ring if it is leaking. I replaced mine. You can get it at the dealer.
Old May 12, 2009 | 01:46 AM
stephenpen's Avatar
Does anyone know if I have to buy a new filter adapter or if I can use the stock parts. I have to change my oil and I would like to remove the cooler at the same time.
thanks in advance
Old May 12, 2009 | 04:33 AM
RUDEDOG's Avatar
Use the stock adapter. You will need 2 new bolts or cut the the tops off the old ones. It will make sense once you see it.
Old Oct 19, 2019 | 08:01 AM
KYWes's Avatar
Re: oil cooler delete
I recently did this to my '95Z. I went to my hardware store and bought two bolts to replace the stock ones. Worked great. I'll pass on as I was told that you can also go to the M302 Mobil oil filter that holds almost a quart of oil!
Old Oct 19, 2019 | 08:32 AM
The confusion may be due to the fact there are two different oil cooler designs.
94 - https://www.camaroz28.com/g/picture/8154201
95 - http://shbox.com/1/oil_cooler.jpg
Old Oct 21, 2019 | 04:00 AM
chevykid's Avatar
Originally Posted by Injuneer
Fred, is coolant going through #4 on the oil filter or is oil going through the radiator?
Thanks!
Old Oct 21, 2019 | 08:51 AM
Coolant flows through the outside of the cooler. Oil flows from 3 to 5 through the middle. That's an assumption. I've only physically seen the 94 setup.
*Emilia*
Jul 15, 2014 09:53 AM
F550maranello2
Jun 29, 2011 07:30 AM
ENRKyle20
Jul 18, 2008 09:42 PM
scoobysnax83
Feb 13, 2004 11:37 AM
1FastRedZ
Oct 11, 2003 06:02 PM
