Odd cam question
Old Jan 15, 2004 | 09:38 PM
  #61
ibanez6rg's Avatar
Originally posted by engineermike
I don't get it.
There was that big hype how Lunati cranks were bad after June or July...
Old Jan 15, 2004 | 09:56 PM
  #62
dnz28's Avatar
I agree also with what ws stated above,I have been looking at different durations and lifts and so forth but I just cant decide i just keep getting ideas then some how void it out and start from square one over and over just seeing what will best suit my needs. so far I got nothin.
Old Jan 15, 2004 | 10:48 PM
  #63
engineermike's Avatar
Using Extreme energy lobes is always a good thing - you just need the proper spring pressure to control the valvetrain under the aggresive ramps. Around 140# on the seat will do.
Use the high-lift lobes if you're confident you have retainer/valve seal clearance and the springs won't coil bind.
I wrote a DCR calculator for Excel. I can figure your DCR is you give me:
bore
stroke
piston dish cc
chamber cc
deck height
gasket thickness
intake advertised duration
cam LSA
cam advance
Mike
Old Feb 24, 2004 | 10:25 PM
  #64
SVT Killer LV's Avatar
Any progress on this project?
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
slocody
Feb 10, 2003 01:04 PM
