Odd cam question
Old Jan 14, 2004 | 09:27 PM
  #16
ibanez6rg's Avatar
Originally posted by engineermike
Pleeeeeeese tell me you're not attempting this with Edelbrock headers and a FlowDisaster muffler. . .
Mike
Old Jan 14, 2004 | 09:33 PM
  #17
marshall93z's Avatar
quote:
Originally posted by marshall93z
i also have heard about this...i guess if you had a 93, which i think is batch fire, you wouldnt have to worry about injector timing.
Originally posted by ibanez6rg
Wrong. It still wouldn't work.
but doesnt batch fire fire every injector once per crankshaft revolution?
Old Jan 14, 2004 | 09:34 PM
  #18
dnz28's Avatar
nonononononononononno did i forget to say no. I am building a stroker motor right now so dont get you muffler tubing tied in a knot, I have dynotech long tubes for this bad boy.Long live the header muffs!!!!!
Old Jan 14, 2004 | 09:39 PM
  #19
ibanez6rg's Avatar
It still fires 1-8-4-3-6-5-7-2.
Old Jan 14, 2004 | 09:45 PM
  #20
oh ok, i was under the impression that it fired all injectors at once!
what is the difference then between the two?
Old Jan 14, 2004 | 09:55 PM
  #21
engineermike's Avatar
I thought that sequential injection fired the injectors 18436572, or in 'sequence'.
Batch fire squirts the whole left bank, then the whole right bank.
http://h-body.org/people/projects/bu...ectronics.html
2nd paragraph, about half way through.
Mike
Old Jan 14, 2004 | 10:07 PM
  #22
ibanez6rg's Avatar
Even if the injectors are all fired at the same time. The opti still will fire 1-8-4-3-6-5-7-2.
Old Jan 15, 2004 | 06:55 AM
  #23
Mtrhds94Z's Avatar
But as stated, he'll swap the 4/7 plug wires also... so it'd work..
and it does look like it'd work with batch fire also, by swapping the injector leads[since 4 is one 'bank' and 7 is the other 'bank'..]
If there are cam grinders doing this already, they should do an LT1 cam for you without too much fuss..
Interesting idea... Worth it? Who knows?
Old Jan 15, 2004 | 10:50 AM
  #24
Fastbird93's Avatar
In the 93's Batch Fire system, the injectors on the left bank and right bank are "Batch Fired" I.E. all four at once, each side once per crankshaft revolution.
The opti still fires in the prescribed sequence.
As for the 4-7 swap, that's a TON of work to be doing for just a few HP. I'd need to see substantiated gains and proven facts as to the reasons before even thinking about considering it.
Old Jan 15, 2004 | 11:19 AM
  #25
SVT Killer LV's Avatar
TTT... this is interesting
Old Jan 15, 2004 | 11:28 AM
  #26
ibanez6rg's Avatar
So basically what you're going to do is get a custom ground cam and running 4,7 plugs all over the place. How you'll do it on a 94-97, I don't know. But it may work on a batch fire ignition. Good luck if you try this.
Old Jan 15, 2004 | 12:03 PM
  #27
Mtrhds94Z's Avatar
It wouldn't be that difficult to swap 4/7 plug wires with a custom set..
For 94-7 you'd have to swap the 4/7 injector wires also...
One prob I see is that they are on opposite banks, so if the ECM wants to 'richen'[or lean] one bank you would have the injectors swapped to different sides, so it would interfere somewhat with that..
I assume that batch fire FI still does 'corrections'?[based on O2 info/readings?]
Old Jan 15, 2004 | 01:20 PM
  #28
Fastbird93's Avatar
Yes batch fire does corrections, I've been battling a fuel issue for a while now and constantly watching it.
Now correct me if I'm wrong, but wouldn't the cylinder firing swap also necessitate a new crank for the two cylinders??? Wouldn't you need to swap the compression strokes around too?? Or am I looking to deep into it?
Old Jan 15, 2004 | 02:01 PM
  #29
ibanez6rg's Avatar
No, don't think so. They should both be at TDC at the same time.
Old Jan 15, 2004 | 02:16 PM
  #30
Fastbird93's Avatar
Ok, nevermind.
